node-red-spreadsheet-template 1.0.0
A Node-RED node for rendering spreadsheets using a spreadsheet template.
npm install node-red-spreadsheet-template
build status
Use this node to create spreadsheets using a spreadsheet template.
flow
📖 How to test your node
  1. open a terminal in the root of this project
  2. run npm install
  3. run npm run start and wait for your browser to open
1 - Configure the node inputs
Like the payload, all other inputs can be set using the msg object, as follows:
  • msg.templateFilepath
  • msg.templateSheetName
  • msg.outputFilepath
[!IMPORTANT]
msg values take precedence over the values set in the node's form.
2 - Create a spreadsheet template
3 - Define the data
[!IMPORTANT]
msg.payload must be an array of objects.
4 - Run the flow
5 - Verify the output.xlsx
Version: 1.0.0
Updated 1 year, 2 months ago
8 in the last week
  • nrg
