node-red-node-snmp 2.0.0
A Node-RED node that gets and sets SNMP oid values. Supports v1, v2c and v3
npm install node-red-node-snmp
node-red-node-snmp
A set of Node-RED nodes that fetch values from SNMP enabled hosts. Supports v1, v2c and v3.
  • SNMP get - Simple SNMP oid or oid list fetcher
  • SNMP set - Simple snmp Set node.
  • SNMP subtree - Simple sub tree fetcher
  • SNMP table - Simple SNMP oid table fetcher
  • SNMP walker - Simple SNMP oid walker fetcher
v2 Breaking Change
v2 has a breaking change in that the single snmp node no longer tries to stringify an octet string type (04). This makes it consistent with the other nodes in this bundle. this means the user now has to convert to a string if required but has better control of how they wish to do that.
snmp
SNMP oids fetcher. Can fetch a single or comma separated list of oids. Triggered by any input.
msg.host may contain the host including the port.
msg.community may contain the community. (v1 and v2c only)
msg.username may contain the username. (v3 only)
msg.authkey may contain the digest security key. (v3 only)
msg.privkey may contain the encryption security key. (v3 only)
msg.oid may contain a comma separated list of oids to search for. (no spaces)
The host configured in the edit config will override msg.host. Leave blank if you want to use msg.host to provide input.
The community configured in the edit config will override msg.community. Leave blank if you want to use msg.community to provide input.
The username configured in the edit config will override msg.username. Leave blank if you want to use msg.username to provide input.
The digest security key configured in the edit config will override msg.authkey. Leave blank if you want to use msg.authkey to provide input.
The encryption security key configured in the edit config will override msg.privkey. Leave blank if you want to use msg.privkey to provide input.
The oids configured in the edit config will override msg.oid. Leave blank if you want to use msg.oid to provide input.
Outputs msg.payload containing a table of objects, and the requested msg.oid. Values depends on the oids being requested.
snmp-set
SNMP sets the value of one or more OIDs.
msg.varbinds may contain an array of varbind JSON objects e.g.:
    msg.varbinds = [
            "oid": "1.3.6.1.2.1.1.5.0",
            "type": "OctetString",
            "value": "host1"
            "oid": "1.3.6.1.2.1.1.6.0",
            "value": "somewhere"
Types can be:
  • Boolean
  • Integer
  • OctetString
  • Null
  • OID
  • IpAddress
  • Counter
  • Gauge
  • TimeTicks
  • Opaque
  • Integer32
  • Counter32
  • Gauge32
  • Unsigned32
  • Counter64
  • NoSuchObject
  • NoSuchInstance
  • EndOfMibView
The varbinds configured in the edit config will override msg.varbinds. Leave blank if you want to use msg.varbinds to provide input.
snmp-table
Simple SNMP table oid fetcher. Triggered by any input.
The oid configured in the edit config will override msg.oid. Leave blank if you want to use msg.oid to provide input.
Outputs msg.payload containing the table of objects, and the requested msg.oid. Values depends on the oids being requested.
snmp-subtree
Simple SNMP oid subtree fetcher. Triggered by any input. Reads from OID specified and any below it.
msg.oid may contain the oid of a single table to search for.
snmp-walker
Simple SNMP oid walker fetcher. Triggered by any input. Reads from OID specified to the end of the table.
Version: 2.0.0
Updated 2 years, 3 months ago
Rating: 5.0 5
303 in the last week
  • snmp
  • snmp set
  • snmp table
  • snmp subtree
  • snmp walker
  • snmp
  • oid
  • snmpv3
  • Mika Karaila
  • Bryan Malyn
  • Steve-Mcl
  • Andres
  • @echobops
