node-red-contrib-wemo-emulator 1.0.5
**NOTE** if you're upgrading from a version prior to 1.0.0, it is recommended that you get Alexa to forget all devices and rediscover. This is due to the fix to prevent duplicated wemo-emulator devices appearing in the Alexa app.
npm install node-red-contrib-wemo-emulator
NOTE if you're upgrading from a version prior to 1.0.0, it is recommended that you get Alexa to forget all devices and rediscover. This is due to the fix to prevent duplicated wemo-emulator devices appearing in the Alexa app.
Why might you want to emulate Wemo? Well I wanted to be able to control my Node-RED Raspberry Pi using my Amazon Echo. The Echo has Wemo support built in so I thought I'd give it a try.
It's pretty cool to be able to say 'Alexa, turn my garden watering system on' and my Pi turns on the outdoor watering system.
This Node-RED node is only a slim wrapper around the marvellous wemore Wemo library written by Daniel Leong.
Change directory to your node red installation:
$ npm install node-red-contrib-wemo-emulator
Drag the node on to your workspace, configure it as below and then ask Alexa to discover devices.
Config Description
Node Name This is the name of the node as it appears in the Node-RED workspace
Friendly Name This is the name that you'll see in the list of devices known to Alexa, it's also the name that you use in voice commands
Unique ID This ID should be unique across all the wemo-emulator nodes in your workspace
Port Wemore can automatically select a port to listen on, but it is recommended that you enter a unique port and increment it for each wemo emulator node you add to your workspace. This ensures that the port never changes.
On Topic This is the topic sent when you ask Alexa to turn your thing on
On Payload This is the payload sent when you ask Alexa to turn your thing on
Off Topic This is the topic sent when you ask Alexa to turn your thing off
Off Payload This is the payload sent when you ask Alexa to turn your thing off
Troubleshooting
If Alexa can't discover the devices emulated by this node, please check you don't have a firewall blocking the following ports:
  • 1900/udp
  • You must also open the ports for all of the wemo emulator nodes configured
Enabling extra debugging
Install node-red-contrib-config and drag a config node into your workspace. Configure the node to set a global variable called wemo-emulator with a JSON value of {"debug": true}. Also make sure that the config tickbox for active is unchecked. Redeploy. Now click the button on the config node. This will trigger all instances of wemo-emulator to write extra logging to the os syslog next time they're invoked.
Experimental
The node-red msg object now contains a sender object which attempts to identify the echo which was spoken to. This is still under scrutiny and may or may not work for you.
Version: 1.0.5
Updated 3 years, 1 month ago
Rating: 3.7 3
38 in the last week
  • wemo-emulator
  • wemo
  • emulator
  • amazon
  • echo
  • alexa
