node-red-contrib-tinkerforge-openinc 0.0.37
Node-RED Nodes to access Tinkerforge Sensors
npm install node-red-contrib-tinkerforge-openinc
A small set of Node-RED Nodes
These nodes make use of Tinkerforge's javascript library to connect to a local brickd instance or to a remote instance (via Ethernet/WiFi brick)
This repository is a fork of repository tyrrellsystems. A small selection of nodes has been retained and partially modified.
From npm
Supported Bricklets
Currently there are nodes for the following bricklets
  • Humidity V2 Bricklet
  • Motion Detector V2 Bricklet
  • Rotary Poti V2 Bricklet
  • Distance IR V2 Bricklet
  • LCD 128x64 Bricklet
  • RGB LED Button Bricklet
  • Accelerometer V2 Bricklet
  • Energy Monitor Bricklet
  • Industrial Digital In 4 V2 Bricklet
  • Laser Range Finder V2 Bricklet
  • Load Cell V2 Bricklet
  • Temperature V2 Bricklet
  • LED Strip V2 Bricklet
  • DC V2 Bricklet
  • Servo V2 Bricklet (only Position for Servo 0)
Adding more should be pretty trivial, these are just the bricks I currently access to for testing
Apache 2.0
Version: 0.0.37
Updated 7 months, 2 weeks ago
  • TinkerForgeConfig
  • TinkerForge MotionV2
  • TinkerForge AccelerometerV2
  • TinkerForge EnergyMonitor
  • TinkerForge IndustrialDigitalIn4V2
  • TinkerForge LaserRangeFinderV2
  • TinkerForge LoadCellV2
  • TinkerForge BrickletLEDStripV2
  • TinkerForge TemperatureV2
  • TinkerForge HumidityV2
  • TinkerForge RotaryPotiV2
  • TinkerForge DistanceIRV2
  • TinkerForge RGBButton
  • TinkerForge RGBLight
  • TinkerForge LCD
  • TinkerForge BrickletServoV2
  • TinkerForge BrickletDCV2
  • tinkerforge
  • node-red-contrib-tinkerforge-openinc
