node-red-contrib-throttle 0.1.7
A Node-RED node to throttle down passed through message amount.
npm install node-red-contrib-throttle
GitHub version NPM version Dependencies Status
A Node-RED node to throttle down outgoing messages.
Table of Contents
Run the following command in your Node-RED user directory - typically ~/.node-red:
A simple node to throttle down passed through message amount. Just insert the throttle node in between two others, and the passed through message amount can be limited by different parameters. Every other messages will be dropped.
By Time
Limits the passed through messages by a given amount of time.
For example: setting the node to 10 seconds means, that only one message in ten seconds will be forwarded.
By Count
Limits the passed through messages by a given count.
For example: setting the node to a count of 5 means, that only every fifth message will be forwarded.
By Block Size
Limits the passed through messages by a given block size. The counter will be reset when a message with msg.reset was received.
For example: setting the node to a block size of 5 means, that only the first five messages will be forwarded.
By Reset
Will only pass through a single message, when a message with msg.reset was received before.
Example Flows
Simple examples showing how to use the throttle and it's output.
Example by Time
[{"id":"81be4802.e74478","type":"function","z":"8a25646f.9d541","name":"info msg","func":"msg.payload = \"injected\";\nreturn msg;","outputs":1,"noerr":0,"x":800,"y":60,"wires":[["789ee5ac.32e214"]]},{"id":"789ee5ac.32e214","type":"debug","z":"8a25646f.9d541","name":"output","active":true,"console":"false","complete":"payload","x":950,"y":80,"wires":[]},{"id":"99fbadf5.9b42e8","type":"throttle","z":"8a25646f.9d541","name":"","throttleType":"time","timeLimit":"3","timeLimitType":"seconds","countLimit":"3","blockSize":0,"locked":false,"x":800,"y":100,"wires":[["789ee5ac.32e214"]]},{"id":"681f30ee.8f3598","type":"inject","z":"8a25646f.9d541","name":"inject","topic":"","payload":"!!! PASSED THROUGH !!!","payloadType":"str","repeat":"","crontab":"","once":false,"x":650,"y":80,"wires":[["99fbadf5.9b42e8","81be4802.e74478"]]}]
Example by Count
[{"id":"a3d7f710.99f97","type":"debug","z":"8a25646f.9d541","name":"output","active":true,"console":"false","complete":"payload","x":950,"y":200,"wires":[]},{"id":"e2c6599a.0b5c98","type":"function","z":"8a25646f.9d541","name":"info msg","func":"msg.payload = \"injected\";\nreturn msg;","outputs":1,"noerr":0,"x":800,"y":180,"wires":[["a3d7f710.99f97"]]},{"id":"8a2c177f.24e0c8","type":"throttle","z":"8a25646f.9d541","name":"","throttleType":"count","timeLimit":"10","timeLimitType":"seconds","countLimit":"3","blockSize":0,"locked":false,"x":800,"y":220,"wires":[["a3d7f710.99f97"]]},{"id":"836ebd21.ad25","type":"inject","z":"8a25646f.9d541","name":"inject","topic":"","payload":"!!! PASSED THROUGH !!!","payloadType":"str","repeat":"","crontab":"","once":false,"x":650,"y":200,"wires":[["8a2c177f.24e0c8","e2c6599a.0b5c98"]]}]
Example by Block Size
[{"id":"32aac7a2.1c4d2","type":"function","z":"8a25646f.9d541","name":"info msg","func":"msg.payload = \"injected\";\nreturn msg;","outputs":1,"noerr":0,"x":800,"y":300,"wires":[["cc05fc6b.4e2598"]]},{"id":"ad1cf860.9c085","type":"throttle","z":"8a25646f.9d541","name":"","throttleType":"block","timeLimit":"10","timeLimitType":"seconds","countLimit":"3","blockSize":"3","locked":false,"x":800,"y":340,"wires":[["cc05fc6b.4e2598"]]},{"id":"8925c66d.9381d8","type":"inject","z":"8a25646f.9d541","name":"inject","topic":"","payload":"!!! PASSED THROUGH !!!","payloadType":"str","repeat":"","crontab":"","once":false,"x":490,"y":320,"wires":[["ad1cf860.9c085","32aac7a2.1c4d2"]]},{"id":"8a84f4e3.491f18","type":"inject","z":"8a25646f.9d541","name":"reset","topic":"","payload":"reset","payloadType":"str","repeat":"","crontab":"","once":false,"x":490,"y":380,"wires":[["c83fa727.0f0b3"]]},{"id":"c83fa727.0f0b3","type":"function","z":"8a25646f.9d541","name":"reset msg","func":"msg.reset = true;\nreturn msg;","outputs":1,"noerr":0,"x":620,"y":380,"wires":[["ad1cf860.9c085","cc05fc6b.4e2598"]]},{"id":"cc05fc6b.4e2598","type":"debug","z":"8a25646f.9d541","name":"output","active":true,"console":"false","complete":"payload","x":970,"y":380,"wires":[]}]
Example by Reset
[{"id":"4e11480f.2fad28","type":"function","z":"8a25646f.9d541","name":"info msg","func":"msg.payload = \"injected\";\nreturn msg;","outputs":1,"noerr":0,"x":800,"y":460,"wires":[["c1d324bd.d2feb8"]]},{"id":"50915215.704714","type":"throttle","z":"8a25646f.9d541","name":"","throttleType":"reset","timeLimit":"10","timeLimitType":"seconds","countLimit":"3","blockSize":0,"locked":false,"x":800,"y":500,"wires":[["c1d324bd.d2feb8"]]},{"id":"4ba961e0.c018c8","type":"inject","z":"8a25646f.9d541","name":"inject","topic":"","payload":"!!! PASSED THROUGH !!!","payloadType":"str","repeat":"","crontab":"","once":false,"x":490,"y":480,"wires":[["50915215.704714","4e11480f.2fad28"]]},{"id":"f786e09d.1cdfa","type":"inject","z":"8a25646f.9d541","name":"reset","topic":"","payload":"reset","payloadType":"str","repeat":"","crontab":"","once":false,"x":490,"y":540,"wires":[["bbf770bd.df0768"]]},{"id":"bbf770bd.df0768","type":"function","z":"8a25646f.9d541","name":"reset msg","func":"msg.reset = true;\nreturn msg;","outputs":1,"noerr":0,"x":620,"y":540,"wires":[["50915215.704714","c1d324bd.d2feb8"]]},{"id":"c1d324bd.d2feb8","type":"debug","z":"8a25646f.9d541","name":"output","active":true,"console":"false","complete":"payload","x":970,"y":540,"wires":[]}]
Bugs / Feature request
Please report bugs and feel free to ask for new features directly on GitHub.
This project is licensed under Apache 2.0 license.
Donation
You like to support me?
You appreciate my work?
You use it in commercial projects?
Feel free to make a little donation! :wink:
Version: 0.1.7
Updated 6 years, 2 months ago
Rating: 4.8 5
205 in the last week
  • throttle
  • throttle
  • limit
