node-red-contrib-text-classify 3.1.18
Text classify with Machine learning for node-red.
npm install node-red-contrib-text-classify
This module for Node-RED contains a set of nodes which offer machine learning functionalities based on Berta model and Tensorflow. Text classify predictions can be performed through the use of this package.
Pre requisites
Be sure to have a working installation of Node-RED.
Install python and the following libraries:
  • Python 3.9.+ accessible by the command 'python' (on linux 'python3')
  • Numpy
  • Pandas
  • SciKit-Learn
  • PyTorch
  • Full pip install: pip install scikit-learn evaluate transformers[torch] datasets nlp pandas nltk langchain_huggingface
  • Run the following in your python after installation:
    • import nltk
    • nltk.download('stopwords')
    • nltk.download('punkt_tab')
    • nltk.download('wordnet')
To install the latest version use the Menu - Manage palette option and search for node-red-contrib-automl, or run the following command in your Node-RED user directory (typically ~/.node-red):
npm i node-red-contrib-text-classify
These flows create a dataset, train a model and then evaluate it. Models, after training, can be use in real scenarios to make predictions. Dataset must contain 'text' (input) and 'label' (target) columns.
Flows and test datasets are available in the 'test' folder. Make sure that the paths specified inside nodes' configurations are correct before trying to execute the program.
Tip: you can run 'node-red' (or 'sudo node-red' if you are using linux) from the folder '.node-red/node-modules/node-red-contrib-text-classify' and the paths will be automatically correct.
This flow loads a training partition and trains a 'text-classify-trainer', saving the model locally. Training
This flow loads a test partition and evaluates a previously trained model. Evaluation
You can also use text-classify-light* nodes as in example flow to split text embedding and classification tasks
You can use text classification model from Hugging Face
Example flows available here:
[{"id":"cde349c1477e8ac6","type":"tab","label":"Example","disabled":false,"info":"","env":[]},{"id":"caa9be34cfeb6e99","type":"inject","z":"cde349c1477e8ac6","name":"Train data sample generator","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[ {\"text\":\"bla-bla\",\"label\":\"talk\"}, {\"text\":\"some message\",\"label\":\"talk\"}, {\"text\":\"I will kill you\",\"label\":\"warning\"}, {\"text\":\"fire at me\",\"label\":\"warning\"}, {\"text\":\"mine field\",\"label\":\"warning\"} ]","payloadType":"json","x":360,"y":140,"wires":[["becc44c98f5e462d"]]},{"id":"610f718371104340","type":"inject","z":"cde349c1477e8ac6","name":"Test data sample generator","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[ {\"text\":\"bla\"}, {\"text\":\"message\"}, {\"text\":\"kill\"}, {\"text\":\"fire\"}, {\"text\":\"mine\"} ]","payloadType":"json","x":350,"y":240,"wires":[["9aed3d3835203404"]]},{"id":"9aed3d3835203404","type":"text-classify-predictor","z":"cde349c1477e8ac6","name":"","modelPath":"/tmp","modelName":"somemodel","orient":"records","x":640,"y":240,"wires":[["6ad8a705241d7924"],["3cbcdea3dcd22514"]]},{"id":"becc44c98f5e462d","type":"text-classify-trainer","z":"cde349c1477e8ac6","name":"","savePath":"/tmp","saveName":"somemodel","tokenizerPathOrName":"cointegrated/LaBSE-en-ru","modelPathOrName":"cointegrated/LaBSE-en-ru","orient":"records","x":630,"y":140,"wires":[["a8a1ed5eafbf1964"],["0c6126c42bcbbc67"]]},{"id":"a8a1ed5eafbf1964","type":"debug","z":"cde349c1477e8ac6","name":"good_messages","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":100,"wires":[]},{"id":"0c6126c42bcbbc67","type":"debug","z":"cde349c1477e8ac6","name":"errors and warns","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":910,"y":160,"wires":[]},{"id":"6ad8a705241d7924","type":"debug","z":"cde349c1477e8ac6","name":"good_messages","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":220,"wires":[]},{"id":"3cbcdea3dcd22514","type":"debug","z":"cde349c1477e8ac6","name":"errors and warns","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":910,"y":260,"wires":[]},{"id":"27013483b3180c80","type":"text-classify-text-to-embed","z":"cde349c1477e8ac6","name":"text-classify-text-to-embed","modelPathOrName":"cointegrated/LaBSE-en-ru","orient":"records","x":500,"y":400,"wires":[["02b87ace53cbc9f2","4b51e6c71e39bbd9"],["cc90cd1fecf53b29"]]},{"id":"91ddce031bf7daad","type":"text-classify-light-predictor","z":"cde349c1477e8ac6","name":"text-classify-light-predictor","modelPath":"/tmp","modelName":"lightmodel","orient":"records","x":1050,"y":500,"wires":[["68ae086bd67907a8"],["b3d6ac18d9a39ee1"]]},{"id":"66f8b9407b7cb662","type":"comment","z":"cde349c1477e8ac6","name":"Train with text embedding and classify like 2 in 1","info":"","x":580,"y":60,"wires":[]},{"id":"0bebe1ed963ed6df","type":"comment","z":"cde349c1477e8ac6","name":"Split text embedding and classification","info":"","x":550,"y":320,"wires":[]},{"id":"4b51e6c71e39bbd9","type":"switch","z":"cde349c1477e8ac6","name":"msg.task?","property":"task","propertyType":"msg","rules":[{"t":"eq","v":"train","vt":"str"},{"t":"eq","v":"test","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":850,"y":420,"wires":[["d999196e7c73b4ea"],["91ddce031bf7daad"]]},{"id":"02b87ace53cbc9f2","type":"debug","z":"cde349c1477e8ac6","name":"good_messages","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":760,"y":360,"wires":[]},{"id":"cc90cd1fecf53b29","type":"debug","z":"cde349c1477e8ac6","name":"errors and warns","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":480,"wires":[]},{"id":"faf312069f01360a","type":"debug","z":"cde349c1477e8ac6","name":"good_messages","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1300,"y":320,"wires":[]},{"id":"e9c9c62d7b177548","type":"debug","z":"cde349c1477e8ac6","name":"errors and warns","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1310,"y":380,"wires":[]},{"id":"68ae086bd67907a8","type":"debug","z":"cde349c1477e8ac6","name":"good_messages","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1280,"y":460,"wires":[]},{"id":"b3d6ac18d9a39ee1","type":"debug","z":"cde349c1477e8ac6","name":"errors and warns","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1290,"y":540,"wires":[]},{"id":"421ee8b4dcf6320a","type":"inject","z":"cde349c1477e8ac6","name":"Train data sample generator","props":[{"p":"payload"},{"p":"task","v":"train","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[ {\"text\":\"bla-bla\",\"label\":\"talk\"}, {\"text\":\"some message\",\"label\":\"talk\"}, {\"text\":\"I will kill you\",\"label\":\"warning\"}, {\"text\":\"fire at me\",\"label\":\"warning\"}, {\"text\":\"mine field\",\"label\":\"warning\"} ]","payloadType":"json","x":200,"y":380,"wires":[["27013483b3180c80"]]},{"id":"09eeadbcea6f620e","type":"inject","z":"cde349c1477e8ac6","name":"Test data sample generator","props":[{"p":"payload"},{"p":"task","v":"test","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[ {\"text\":\"bla\"}, {\"text\":\"message\"}, {\"text\":\"kill\"}, {\"text\":\"fire\"}, {\"text\":\"mine\"} ]","payloadType":"json","x":190,"y":460,"wires":[["27013483b3180c80"]]},{"id":"d999196e7c73b4ea","type":"text-classify-light-trainer","z":"cde349c1477e8ac6","name":"text-classify-light-trainer","savePath":"/tmp","saveName":"lightmodel","epochCount":"6","orient":"values","x":1070,"y":360,"wires":[["faf312069f01360a"],["e9c9c62d7b177548"]]}]
Thanks
Thanks to Gabriele Maurina for awesome nodes - node-red-contrib-machine-learning
Version: 3.1.18
Updated 4 months, 2 weeks ago
21 in the last week
  • text-classify-predictor
  • text-classify-trainer
  • text-classify-text-to-embed
  • text-classify-light-predictor
  • text-classify-light-trainer
  • machine learning
  • ml
  • text
  • hugging face
  • text classification
  • classification
