node-red-contrib-swagger-js 1.0.3
Swagger js for node-red
It is based on swagger-js.
Inputs
Name - string
set a manuell name for the node. If no name is set, the node sets the selected operation name.
Container - string
The name of the container that will receive the API object. If no container is set, the node sets the selected API name.
URL - string
set the full url domain name (incl. http:// / https://) for the OpenAPI document. By clicking on 'read' it will build the API and operation Selectors.
API tag - enum
Preselector for the operation. Grouped by the 'tags' in each operation.
Operation - enum
Selector for the OpenAPI operation. The selection name is set by the 'summary'. Behind the selector field is the (unique) operation id. By mouse-over it will show the full operation Description.
Parameters depending
If the selected operation has parameters, they will be listed here. The description can be found by mouse-over the parameter name. If the parameter is required, it will be marked with a red star behind the name. For Json Objects with defined keys there will be 3 Buttons: 'set required' and 'set default' will build a json-object with the correct key names and the necessary type info as the value. 'show keys' show all possible key parameters with additional info by mouse-over the key name.
Outputs
Container - object
Returns the complete API object.
Authentification
The credentials has to be set into msg.authentification.
e.g. msg.authentification = "Bearer ******"
Error handling
This handles how to react if the server returns a http status of 4xx or 5xx. You can find the last server response in msg.response.
Standard - string
The flow will move on normally so you can choose how to handle this within your flow.
Other output - string
The flow will move on in a second output.
Throw exception - string
The flow will throw an exception. This exception can be catched by the 'catch' node.
