node-red-contrib-soundweb 1.0.7
A collection of nodes for controlling BSS soundweb devices.
npm install node-red-contrib-soundweb
platform npm package version license Npm package total downloads github-issues
A collection of nodes for controlling BSS Soundweb devices.
screenshot
Release Notes
Version Description
1.0.7 Updated dependencies
1.0.6 Assign HiQnet address programatically. Documentation
1.0.5 Documentation.
1.0.4 Documentation.
1.0.3 IMPORTANT: Flow breaking changes were introduced in v1.0.3. If you are updating from v1.0.2 or below you will need to you will need to replace nodes with their latest equivalent. Rather than have a node for each scale type and/or command type, functionality has been consolidated into as few nodes as possible. This is to simplify maintenance and updates.
Getting Started
Prerequisites
untested on earlier versions
Install via Node-RED Manage Palette
Install via npm
$ cd ~/.node-red
$ npm install node-red-contrib-soundweb
# then restart node-red
soundweb-server
Configuration node that manages connection to BSS device.
soundweb-server edit dialog
soundweb-Control
Node for setting a controls value.
There are two command types:
  • set state variable
  • set state variable by percentage
There are six scale types:
  • discrete
  • scalar linear
  • gain (dB fader law)
  • delay
  • frequency
  • speed
soundweb-Control edit dialog
soundweb-Presets
Node for recalling presets by index number.
  • parameter preset
  • venue preset
soundweb-Presets edit dialog
Resources
Address Property
The address property is a buffer of exactly 8 bytes. it is comprised of:
  • Node Address (2 bytes)
  • Virtual Device (1 byte)
  • Object ID (3 bytes)
  • Parameter ID (2 bytes)
The following bytes have special meanings. The node suite will automatically handle replacement when commands are encapsulated and decapsulated. Be mindfull on nodes requiring an address property that the non replaced character is needed in decimal format.
TYPE HEX DEC HEX replacement DEC replacement
STX 0x02 2 0x1B, 0x82 27, 130
ETX 0x03 3 0x1B, 0x83 27, 131
ACK 0x06 6 0x1B, 0x86 27, 134
NAK 0x15 21 0x1B, 0x95 27, 149
Escape 0x1B 27 0x1B, 0x9B 27, 155
Feature Requests / Bug Reporting
Please report any bugs or issues to the repository here.
Version: 1.0.7
Updated 1 year, 3 months ago
Rating: 5.0 3
9 in the last week
  • soundweb-server
  • soundweb-Control
  • soundweb-Presets
  • BSS
  • BLU
  • Soundweb
  • Harman
  • Audio DSP
  • Audio Architect
  • London Architect
