node-red-contrib-sentilo 0.5.1
A Sentilo/Thingtia platform server nodes collection for node-red
npm install node-red-contrib-sentilo
What is it?
node-network-contrib-sentilo is a collection of nodes for Node-RED that brings you the possibility to connect to a Sentilo or Thingtia platform server in order to interact with your data in a simple way.
Run the following command in the root directory for your Node-RED install
$ npm install node-red-contrib-sentilo
Package adds 4 nodes to the Node-RED's palette that provide basic interactions with a Sentilo / Thingtia platform server: retrieve, publish and subscribe to data and platform events.
Retrieve Node
Retrieves data from the platform server.
Data types
Possible data types to retrieve are:
  • ALARM
  • ALERT
  • CATALOG
  • DATA
  • ORDER
  • SUBSCRIBE
Depending of data type, you will be able to fill some extra filter parameters, such like limit number of observations, or from/to observations publish dates.
Input / output
This node must be triggered by plugging an inject node in the input. Node will output the returned Sentilo message as well as the HTTP status code, in two separate outputs.
Publish Node
Publishes data to the Thingtia / Sentilo platform server.
Data types
You can publish data of types:
  • ALERT
  • CATALOG
  • DATA
  • ORDER
Input / output
This node must be triggered via an inject node on the input (event might either be empty or might contain a JSON payload input message). Node will output the returned Sentilo message (if any) as well as the HTTP status code, in two separate outputs.
Subscribe With Endpoint node
Creates a HTTP endpoint that will use Sentilo to forward its event messages. Your Node-RED instance has to be therefore reachable from your Sentilo instance. Also creates a subscription to a Sentilo/Thingtia platform server via API. Possible data types are:
  • ALARM
  • DATA
  • ORDER This node is an all-in-one Sentilo subscription feature. It is ideal if you need to subscribe to single channel (be it one data type, one sensor, one provider etc).
Input / output
No input - the Subscribe With Endpoint Node is activated on Node-Red flow deployment. At this moment it creates the HTTP endpoint, as well as it creates or re-creates the subscription. Outputs:
  • First output returns the retrieved subscription notification messages.
  • Second output returns Sentilo response message of the subscription creation call (executed only once on each deploy)
  • Third output returns Sentilo HTTP status code of the subscription creation call (executed only once on each deploy)
Subscribe Without Endpoint node
At a difference with the previous node, this node only creates a subscription to a Sentilo/Thingtia platform server via API. Another HTTP have to be used as callback URL, for example "Http In" node of even "Subscribe With Endpoint". Possible data types are:
  • ALARM
  • DATA
  • ORDER This node is created for bulk-manage the subscriptions. It can be parametrized by properties in the incoming msg object.
Input / output
The Subscribe Without Endpoint Node has one input and expects given properties in the msg object.
  • First output returns Sentilo response message of the subscription creation call
  • Second output returns Sentilo HTTP status code of the subscription creation call
Related documentation
Please, feel free to look into the official Sentilo/Thingtia documentation to get more info:
Revisions
  • 0.5.1
    • Sentilo/Thingtia API token in plaintext. Environment variable use encouraged.
  • 0.4.0
    • Compatibility with Node-RED's environment variables
  • 0.3.0
    • Added the 'subscribe-without-endpoint' node
    • The 'subscribe' node renamed to 'subscribe-with-endpoint'
  • 0.2.0
    • Node-RED 1.0 compatibility
    • Fixed server configuration, allowing non-standard ports
    • All nodes get specific outputs with HTTP status of the Sentilo REST API call. Can be useful for handling errors.
  • 0.1.5
    • Solved some litle visual issues
  • 0.1.4
    • Added one dependency, that add support to old node.js versions
  • 0.1.3
  • 0.1.2
    • Added catalog support to the publish node
    • Modified the format of the response message in case of error in the connection to the platform, now the payload and the error message returned are shown
  • 0.1.1
    • Fixed some errors in the connection and data processing
  • 0.1.0
    • First version
Version: 0.5.1
Updated 4 years, 6 months ago
License: EUPL-1.1 AND LGPL-3.0-only
27 in the last week
  • retrieve
  • publish
  • subscribe-with-endpoint
  • subscribe-without-endpoint
  • server
  • sentilo
  • thingtia
  • iot
  • Ruben Rodríguez
  • Jordi Marqués
  • Karel Cech
