node-red-contrib-padavan 1.0.1
Router management with Padavan firmware
npm install node-red-contrib-padavan
credentials |
Description |
repo |
Repository where firmware builds are hosted |
branch |
Branch for the device |
token |
Access token for GitHub |
host |
Router IP address |
username |
Username for router access |
password |
Password for router access |
SpeedTest
Measure download and upload speeds
Output
outputs |
Description |
result |
Result |
history |
Result with date and timestamp |
progress |
Test start and end |
result.msg |
type |
Value |
topic |
string |
NetworkControl |
payload |
object |
payload |
Description |
networkDownloadSpeedMbps |
Download speed |
networkUploadSpeedMbps |
Upload speed |
Devices
Get the list of connected devices
Output
msg |
type |
payload |
array |
numConnectedDevices |
integer |
payload |
hostname |
ip |
mac |
rssi |
History
Retrieve traffic history
Output
msg |
type |
payload |
object |
networkUsage |
string |
networkUsageMB |
integer |
payload |
type |
Description |
daily_history |
array |
Daily |
monthly_history |
array |
Monthly |
*_history |
Description |
0 |
Year, month, day |
1 |
Download |
2 |
Upload |
Updates
Manage firmware updates
topic |
Description |
build |
Build firmware |
changelog |
List of changes |
upgrade |
Install firmware |
Output
msg |
type |
Value |
topic |
string |
changelog |
error |
string |
payload |
object |
payload |
Description |
from_id |
Current firmware |
to_id |
Built firmware |
data |
Array of changes |
Status
Retrieve and manage router status
topic |
Description |
status |
Get current status |
log |
Get logs |
reboot |
Reboot |
Output
msg |
type |
Value |
topic |
string |
status |
payload |
object |
payload |
Description |
lavg |
System load average over the last 1, 5, and 15 minutes |
uptime |
Router uptime |
ram |
RAM usage information |
swap |
Swap memory status |
cpu |
CPU load information |
wifi2 |
Wi-Fi status on the 2.4 GHz band |
wifi5 |
Wi-Fi status on the 5 GHz band |
logmt |
Timestamp of the last log modification |
uptime |
days |
hours |
minutes |
ram |
Description |
total |
Total RAM (in KB) |
used |
Used RAM |
free |
Free RAM |
buffers |
RAM used for buffers |
cached |
RAM used for cache |
cpu |
Description |
busy |
Total time the CPU has been busy |
user |
Time spent on user processes |
nice |
Time spent on processes with modified priority |
system |
Time spent on system processes |
idle |
Idle time when the CPU was not busy |
iowait |
Time spent waiting for I/O operations |
irq |
Time spent on hardware interrupt handling |
sirq |
Time spent on software interrupt handling |
total |
Total units of time since the system started |
wifi* |
Description |
state |
Network state |
guest |
Guest network state |
Parameters
Retrieve and modify parameters
msg |
type |
payload |
object |
topic |
string |
topic |
Description |
list |
Retrieve all parameters |
get |
Retrieve specific parameters |
set |
Modify parameters |
payload |
sid_list |
action_mode |
Output
msg |
type |
topic |
string |
payload |
object |
Details
If sid_list
is specified, changes will be sent via the web panel.
If action_mode
is not specified, it will be sent as Apply
