node-red-contrib-opcua-server 1.1.1
Node-RED contribution nodes with next generation OPC UA in a compact and less dependencies package.
npm install node-red-contrib-opcua-server
Platform Node-RED Contrib OPC UA License NPM version NodeJS_Version Standard - JavaScript Style Guide NPM download Repository GitHub Build and publish Codacy Badge
A programmable OPC UA server for Node-RED based on node-opcua next generation version with less dependencies.
using next generation node-opcua version from Etienne Rossignon
try these options on npm install to build from source if you have problems to install
    --unsafe-perm --build-from-source
Debug
Debugging on remote devices is important to help users. The verbose logging provides interesting points in different abstractions if IDE or console debugging is not possible.
Start debug with Node-RED in verbose (-v) mode to get a verbose logging:
DEBUG=opcuaCompact* node-red -v 1>Node-RED-OPC-UA-Server.log 2>&1
or on local Node-RED
DEBUG=opcuaCompact* node red.js -v 1>Node-RED-OPC-UA-Server.log 2>&1
Code Style
Prettier
Contribution
Yes, sure! Please help us to make it even better and send your pull requests or tests!
Happy coding!
based on node-opcua we use MIT license Copyright (c) 2019 Bianco Royal Software Innovations®
Version: 1.1.1
Updated 3 years, 1 month ago
Rating: 3.8 6
190 in the last week
  • opcua-compact-server
  • opcua-server
  • automation
  • iiot
  • biancoroyal
