node-red-contrib-node-reddit 1.0.11
Interact with Reddit using Node-RED
npm install node-red-contrib-node-reddit
Overview
Interact with Reddit using Node-RED.
For more detailed information about functionality, inputs, and outputs, visit the wiki or the node's documentation window within the Node-RED editor.
  • Config: authentication for the Reddit API
  • Stream: stream submissions and comments from a subreddit or PMs from your inbox
  • Get: get submissions, comments, or personal messages from a subreddit, user, your inbox, or the content's id, according to its configuration
  • Create: create a new Reddit submission or PM
  • Reply: reply to a submission, comment, or PM
  • Search: perform a Reddit search query in a subreddit
  • Edit: edit a Reddit submission or comment.
  • Delete: delete a Reddit submission, comment, or PM.
  • React: save/unsave and/or vote/unvote on Reddit content.
Populating fields
For all nodes other than config and stream, all text fields may be hardcoded via text or dynamically populated via mustache syntax relative to the incoming msg object.
For example, let's say you're getting hot submissions from a subreddit using the get node. If the target subreddit is located in msg.payload.target, then you can fill in {{payload.target}} in the subreddit field.
Example flows
Develop an interactive website that displays a subreddit. Download the flow.
Nba
Nba
Create a Node-RED dashboard for a subreddit. Download the flow.
Nba
Nba
Create a Reddit bot that responds to a trigger. Download the flow.
Nba
Overwrite and delete all of your Reddit comments. Download the flow.
Overwrite and delete comments
Track the pulse of a subreddit by monitoring the most frequently mentioned words and sentiment of its comments. Download the flow.
Nba
Nba
References
Version: 1.0.11
Updated 5 years, 6 months ago
Rating: 5.0 3
41 in the last week
  • reddit-credentials
  • stream
  • get
  • create
  • reply
  • search
  • edit
  • delete
  • react
  • reddit
  • John Costello
  • William Sabbatini
  • Lucy Song
