node-red-contrib-modbustcp-box 1.2.1
Node-RED nodes for communicating with a MODBUS TCP Server on groov Edge Appliance.
npm install node-red-contrib-modbustcp-box
ONLY CHANGED MODULE NAME TO PRESERVE OLD MODULE VERSION (node dependency lower) NPM
Node-Red Modbus TCP nodes for communicating with a Modbus TCP server.
Based on jsmodbus.
modbus read
alt tag
API
In addition, you can pass in a msg with one or more payload settings to initiate additional modbus read events.
msg.payload = {
    "name": "Name1", // Should be a unique name
    "topic": "topic1", // Override default topic
    "dataType": "FC3", // can be format 3, "FC3", or "Coil"
    "address": 0, // starting address
    "quantity": 4, // # of units to read
    "interval": 3000, // polling interval in milliseconds
    "ieeeType": "off", // valid values are "off", "single" or "double"
    "ieeeBE": true // Big Endian format, true/false. false = little endian
Most of the values are optional and server to override the defaults set in the nodes config.
Values for dataType inlcude:
  • "Coil", "FC1", "FC 1", 1
  • "Input", "FC2", "FC 2", 2
  • "HoldingRegister", "FC3", "FC 3", 3
  • "InputRegister", "FC4", "FC 4", 4
If you pass in a msg with a payload.name that is the same as one previously passed in, the new values will replace the old. For example, it is possible to change the polling interval of an existing event by passing in the same msg structure with a different "interval" setting.
Note: The IEEE 754 formatting is not applied to binary data types such as "Coil" and will be ignored for those.
Note: Setting ieeeBE = false will for the node to read the inputs as "little endian".
Stop/Kill You can stop or kill the polling of a modbus item by passing in the following:
alt tag
The polled event with the same name given will be stopped if the kill=true is also passed in.
example single input
alt tag
example multiple input
alt tag
modbus write
alt tag
API
In addition to passing in a payload value for writing, you can also pass in the following in your msg to override the configured defaults:
  • dataType
    • "Coil", "FC5", "FC 5", 5
    • "HoldingRegister", "FC6", "FC 6", 6
    • "Coils", "FC15" "FC 15", 15
    • "HoldingRegisters", "FC16", "FC 16", 16
  • address
example message input:
msg = {
    address: 8,
    dataType: "Coil",
    payload: 1
Author
Version: 1.2.1
Updated 7 years ago
6 in the last week
  • modbustcp-server
  • modbustcp-write
  • modbustcp-read
  • modbus
  • modbus tcp
  • modbus client
