node-red-contrib-log-elk 1.3.4
A Node-RED logging node with multiple outputs using the winston,winston-elasticsearch and winston-loki logging libraries
npm install node-red-contrib-log-elk
node-red-contrib-log-elk is a Node-RED logging output node that supports multiple logging destinations, including ElasticSearch, Loki (Grafana), local files, the system console, and the Node-RED debug window. This node is designed to provide flexible and configurable logging options for Node-RED flows.
  • ElasticSearch Integration: Log messages to an ElasticSearch instance with support for authentication.
  • Loki Integration: Log messages to a Loki instance with support for headers, authentication, and app labels.
  • File Logging: Log messages to a local file with configurable file size and rotation options.
  • System Console Logging: Log messages to the system console for debugging and monitoring.
  • Debug Window Logging: Log messages to the Node-RED debug window for easy access during development.
  • Dynamic Configuration: Use environment variables to dynamically configure logging options.
Logging Outputs
This node supports the following logging outputs:
  1. ElasticSearch:
    • Elastic URL: The URL of your ElasticSearch instance (e.g., http://localhost:9200).
    • Username: The username for authentication (if required).
    • Password: The password for authentication (if required).
  2. Loki:
    • Loki URL: The URL of your Loki instance (e.g., http://localhost:3100).
    • Headers (JSON): Additional headers to include in requests, specified as a JSON object. Example:
          "X-Scope-OrgID": "${TENANT}"
    • App Label: A label to identify the application in Loki logs (e.g., node-red).
  3. File:
    • Filename: The name of the log file (e.g., log-elk.log).
    • File Size: The maximum size of the log file in megabytes (minimum: 1 MB).
    • Max Files: The maximum number of log files to retain (minimum: 1).
  4. System Console:
    • Logs messages to the system console for debugging or monitoring.
  5. Debug Window:
    • Logs messages to the Node-RED debug window for easy access during development.
Environment Variables
You can use environment variables to dynamically configure the logger. For example, instead of hardcoding the ElasticSearch URL or Loki credentials, you can use ${ENV_VAR} syntax in the fields. At runtime, these placeholders will be replaced with the corresponding environment variable values.
Dependencies
This project uses the following libraries:
Credits
Initial parts of this project were based on node-red-contrib-advance-logger.
This project is licensed under the MIT License. See the LICENSE file for details.
Version: 1.3.4
Updated 1 month ago
156 in the last week
  • log-elk
  • log-elk-logger
  • logger
  • winston
  • elasticsearch
  • loki
