node-red-contrib-aws-cognito-adapter 1.0.5
AWS Cognito adapter to create and authenticate users
This is a helper node that uses the amazon-cognito-identity-js to create and authenticate users inside AWS Cognito.
Mandatory/Default Inputs - on all nodes
Name
Display name of the Node.
TargetAttribute
Defines the Attribute of the msg
Object that will store the valid Token.
Defaults to msg.payload
Userpool Id
Id of the Cognito Userpool.
Format starts with a region, followed by an ID (e.g.: eu-west-1_SoMeId).
Client Id
Client ID or Webclient ID, as provided by Cognito.
Inputs - User Login
Username
The user name of the Cognito Account, typically a email address.
This can also be provided as a parameter to the inbound message on attribute msg.username
If the msg.username
is present on the input, it will be removed before the message is send forward.
Password
The Password of the Cognito Account.
This can also be provided as a parameter to the inbound message on attribute msg.password
If the msg.password
Inputs - Create User
First Name
The first name of the Cognito Account.
This can also be provided as a parameter to the inbound message on attribute msg.firstName
If the msg.firstName
Email
The email address of the Cognito Account.
This can also be provided as a parameter to the inbound message on attribute msg.email
If the msg.email
Mobile Number
The mobile number of the Cognito Account.
This can also be provided as a parameter to the inbound message on attribute msg.mobileNumber
If the msg.mobileNumber
Password
If the msg.password
Inputs - Verify Email
Email
If the msg.email
Code
The email verification received from Cognito.
This can also be provided as a parameter to the inbound message on attribute msg.code
If the msg.code
Output
msg.payload
Dependencies
- amazon-cognito-identity-js
