node-red-contrib-aedes 0.13.0
Node Red MQTT broker node based on aedes.js
npm install node-red-contrib-aedes
MQTT Broker for Node-RED based on Aedes.
You can use the MQTT protocol in Node-RED without an external MQTT broker like Mosquitto.
Node.js CI js-semistandard-style Codacy Badge
Open Source Love NPM version
Background
This node was created because the original MQTT broker node-red-contrib-mqtt-broker uses mosca which is no longer maintained.
You can install the node directly within the editor by using the Palette Manager.
To install the node from the command-line, you can use the following command from within your user data directory (by default, $HOME/.node-red):
Flows
Just put this node on Node-RED and hit the deploy button. The MQTT Broker will run on your Node-RED instance. flows
  • Standard TCP Support
  • WebSocket Support via port or path
  • SSL / TLS
  • Message Persistence (In-memory, LevelDB or MongoDB)
For more information see Aedes.
Server without public IP or behind firewall
If your server is behind a firewall or you cannot open any ports other than the standard http/https ports, the MQTT broker node can be accessible by public clients through a WebSocket path.
When your Node-RED server address is https://yourserver/, you can set the WebSocket to bind to, e.g., "/ws/mqtt" path, to have wss://yourserver/ws/mqtt WebSocket at port 443.
You can also bind the WebSocket to the root "/" path and having wss://yourserver/ WebSocket listening at port 443 (or ws://yourserver/ at port 80).
Licensed under MIT.
Version: 0.13.0
Updated 1 year, 4 months ago
Rating: 4.6 17
1284 in the last week
  • aedes broker
  • aedes
  • mqtt
  • zuhito
  • Jochen Scheib
  • Ori Novanda
