factory-agent-gemini 1.0.6
A Node-RED node for interacting with Google's Gemini AI API
npm install factory-agent-gemini
Node-RED Gemini Agent
A Node-RED node for interacting with Google's Gemini AI models.
English | 中文
English
Overview
The Factory Agent Gemini node provides a simple way to integrate Google's Gemini AI capabilities into your Node-RED flows. This node lets you send prompts to Gemini models and receive AI-generated responses that can be used for various automation and processing tasks.
  • Support for gemini-2.0-flash and gemini-2.0-flash-lite models
  • Configurable temperature and max token parameters
  • System prompt customization
  • Detailed response information including full API response
  • Flow state tracking via flow.agentstate
Alternatively, you can use the Node-RED Palette Manager to install the node.
Node Configuration
  • Name: Optional name for the node instance
  • API Key: Your Google Gemini API key (required)
  • Model: Select the Gemini model to use
  • Temperature: Controls randomness in generation (0.0-1.0)
  • Max Tokens: Maximum output tokens in the response
Input Properties
The node accepts the following message properties:
Property Type Description
payload string/object Main content to send to Gemini
sysPrompt string System prompt to guide Gemini's behavior
envPrompt string Environment context (used if payload not present)
state string Current state info (used if payload not present)
Output Properties
The node outputs a message with these properties:
payload object Complete API response
result string Extracted text response from Gemini
geminiRequest object Request object that was sent to the API
finishReason string Reason why generation stopped (if provided)
Example Flow
        "id": "5b913f59.14274",
        "type": "inject",
        "z": "2a1c7b.4e05694",
        "name": "Ask a question",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "Explain how Node-RED works in simple terms",
        "payloadType": "str",
        "x": 190,
        "y": 240,
                "7f98bab4.c8a524"
        "id": "7f98bab4.c8a524",
        "type": "factory-agent-gemini",
        "name": "Gemini Agent",
        "model": "gemini-2.0-flash",
        "temperature": "0.7",
        "maxTokens": "2048",
        "x": 390,
        "y": 240,
                "e92c9966.763208"
        "id": "e92c9966.763208",
        "type": "debug",
        "name": "Result",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "result",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 570,
        "y": 240,
MIT
中文
概述
Factory Agent Gemini节点提供了一种将Google的Gemini AI功能集成到Node-RED流程中的简单方法。该节点让您能够向Gemini模型发送提示,并接收AI生成的响应,可用于各种自动化和处理任务。
功能特点
  • 支持gemini-2.0-flashgemini-2.0-flash-lite模型
  • 可配置的温度和最大令牌参数
  • 系统提示自定义
  • 详细的响应信息,包括完整的API响应
  • 通过flow.agentstate跟踪流程状态
安装
或者,您可以使用Node-RED调色板管理器安装节点。
配置
节点配置
  • 名称: 节点实例的可选名称
  • API密钥: 您的Google Gemini API密钥(必填)
  • 模型: 选择要使用的Gemini模型
  • 温度: 控制生成的随机性(0.0-1.0)
  • 最大令牌数: 响应中的最大输出令牌数
输入属性
节点接受以下消息属性:
属性 类型 描述
payload 字符串/对象 发送给Gemini的主要内容
sysPrompt 字符串 引导Gemini行为的系统提示
envPrompt 字符串 环境上下文(在payload不存在时使用)
state 字符串 当前状态信息(在payload不存在时使用)
输出属性
节点输出具有以下属性的消息:
属性 类型 描述
payload 对象 完整的API响应
result 字符串 从Gemini提取的文本响应
geminiRequest 对象 发送到API的请求对象
finishReason 字符串 生成停止的原因(如果提供)
示例流程
        "type": "inject",
        "name": "提问",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "用简单的术语解释Node-RED是如何工作的",
        "x": 190,
        "y": 240,
                "7f98bab4.c8a524"
        "name": "Gemini智能体",
        "x": 390,
        "y": 240,
                "e92c9966.763208"
        "type": "debug",
        "name": "结果",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 570,
        "y": 240,
使用方法
  1. 在Node-RED流程中添加Factory Agent Gemini节点
  2. 配置您的Gemini API密钥和所需参数
  3. 连接输入节点(如inject节点)来提供prompt
  4. 连接输出节点(如debug节点)来查看结果
  5. 部署您的流程并测试
许可证
MIT
Version: 1.0.6
Updated 1 month, 2 weeks ago
Rating: 5.0 2
23 in the last week
  • factory-agent-gemini
  • gemini
  • ai
  • factory
  • agent
  • google
