First Try Bubble.io
Connection whit Bubble.io by using MQTT
[{"id":"d4ac43857b42d783","type":"tab","label":"Fluxo 1","disabled":false,"info":"","env":[]},{"id":"be35d0464d94daf2","type":"mqtt out","z":"d4ac43857b42d783","name":"Bubble.io MQTT","topic":"teste/Temperatura/sala","qos":"1","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"c13881a257f9a0dd","x":560,"y":40,"wires":[]},{"id":"d2b83db21e374ece","type":"http response","z":"d4ac43857b42d783","name":"MQTT Bubble.io","statusCode":"","headers":{},"x":120,"y":120,"wires":[]},{"id":"3b232a8fbf8822fb","type":"http in","z":"d4ac43857b42d783","name":"First Try Bubble.io","url":"/publish","method":"post","upload":false,"swaggerDoc":"","x":130,"y":40,"wires":[["4d0a5b8b633adc95"]]},{"id":"4d0a5b8b633adc95","type":"json","z":"d4ac43857b42d783","name":"","property":"payload","action":"","pretty":false,"x":350,"y":40,"wires":[["be35d0464d94daf2"]]},{"id":"c13881a257f9a0dd","type":"mqtt-broker","name":"","broker":"ip.etecnet.com.br","port":1883,"clientid":"ClientPublicaDado1922542324","autoConnect":true,"usetls":false,"protocolVersion":4,"keepalive":"15","cleansession":true,"autoUnsubscribe":true,"birthTopic":"teste/Temperatura/sala","birthQos":"0","birthRetain":"false","birthPayload":"Connection Bubble.io Bortto Tech","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
Created 2 months, 1 week ago
  • http in (x1)
  • http response (x1)
  • json (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • Bubble.io
