Elan Intergration
Elan make high quality multizone amplifiers which integrate well into their own propriety home automation systems.
This flow allows was written to control an Elan S86 amplifier via RS-232 communication. It may work with other Elan amplifiers, but no other testing has been conducted so far.
This flow will create a Web-UI that will allow the following controls of each Zone:
  • Source
  • Volume
  • Treble
  • Bass
  • Loudness
  • Mute
Requirements
  • Serial Port on the host PC. When connected to the Amplifier a cross over cable is required to connect to the in port of the amplifier.
  • Buffer-Phaser Node-Red flow does the heavy lifting of the breaking down the string generated by the Amplifier. https://flows.nodered.org/node/node-red-contrib-buffer-parser
How it Works
Every 15 seconds a query command is sent to the serial port. The returned message is received and then split up and phased into separate msg.payloads for each amplifier zone. The payloads are ranged to create 0-100% values for each control of each zone. Sliders in the Web-UI will display and allow control of each zone. If adjusted, the values are again phased and a sent back to the amplifier as a command.
References
Known Issues
Ranging is used to give 0 - 100% Sliders. Sliders may fly off and increase in value if some values are selected.
Future
It is hoped in time to create make this flow integrate with Home Assistant.
Query Systemserial requestZone 1 StatusZone 2 StatusZone 3 StatusZone 4 StatusZone 5 StatusZone 6 StatusVolumedebugserial requestswitchrange&S86,VOL,01,rangeTreblerangeBassLoudnessSource&S86,AUD,01,True = 1&S86,MUT,01,True = 1&S86,LUD,01,range&S86,TRE,01,add +range&S86,BAS,01,add +MuteVolumedebugserial requestswitchrange&S86,VOL,02,rangeTreblerangeBassLoudnessSource&S86,AUD,02,True = 1&S86,MUT,02,True = 1&S86,LUD,02,range&S86,TRE,02,add +range&S86,BAS,02,add +MuteVolumedebugserial requestswitchrange&S86,VOL,03,rangeTreblerangeBassLoudnessSource&S86,AUD,03,True = 1&S86,MUT,03,True = 1&S86,LUD,03,range&S86,TRE,03,add +range&S86,BAS,03,add +MuteVolumedebugserial requestswitchrange&S86,VOL,04,rangeTreblerangeBassLoudnessSource&S86,AUD,04,True = 1&S86,MUT,04,True = 1&S86,LUD,04,range&S86,TRE,04,add +range&S86,BAS,04,add +MuteVolumedebugserial requestswitchrange&S86,VOL,05,rangeTreblerangeBassLoudnessSource&S86,AUD,05,True = 1&S86,MUT,05,True = 1&S86,LUD,05,range&S86,TRE,05,add +range&S86,BAS,05,add +MuteVolumedebugserial requestswitchrange&S86,VOL,06,rangeTreblerangeBassLoudnessSource&S86,AUD,06,True = 1&S86,MUT,06,True = 1&S86,LUD,06,range&S86,TRE,06,add +range&S86,BAS,06,add +Mute
Flow 1
[{"id":"256968c0.0d1b98","type":"tab","label":"Elan S86 Amplifier","disabled":false,"info":""},{"id":"8db6d4d6.d3b89","type":"inject","z":"256968c0.0d1b98","name":"Query System","props":[{"p":"payload"}],"repeat":"15","crontab":"","once":true,"onceDelay":"0.5","topic":"","payload":"&S86,QRY,1?","payloadType":"str","x":160,"y":20,"wires":[["841f7d3c.5582f"]]},{"id":"841f7d3c.5582f","type":"serial request","z":"256968c0.0d1b98","name":"","serial":"4a242dbe.325f34","x":410,"y":20,"wires":[["de0e8793.deb378","7fb82f18.16229","4375b9ec.e4f29","d7c7554a.0a4ff","8ae2e0d7.1f0c2","3a767c8d.a76394"]]},{"id":"de0e8793.deb378","type":"buffer-parser","z":"256968c0.0d1b98","name":"Zone 1 Status","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"Zone","offset":11,"length":1,"offsetbit":0,"scale":"1","mask":"0X000F"},{"type":"bool","name":"System Status","offset":12,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Do Not Disturb","offset":12,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"Mute","offset":12,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"AV Status","offset":12,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source","offset":12,"length":1,"offsetbit":0,"scale":"1","mask":"0X0007"},{"type":"bool","name":"WHM Status","offset":13,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Page Trigger","offset":13,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"DRC Status","offset":13,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"Loudness","offset":13,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source +7","offset":13,"length":1,"offsetbit":4,"scale":"1","mask":"0X0007"},{"type":"int8","name":"Volume","offset":14,"length":1,"offsetbit":4,"scale":"1","mask":"0X003F"},{"type":"int8","name":"Treble","offset":15,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"},{"type":"int8","name":"Bass","offset":16,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":140,"y":120,"wires":[["7419f7a4.f8a888"]]},{"id":"7fb82f18.16229","type":"buffer-parser","z":"256968c0.0d1b98","name":"Zone 2 Status","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"Zone","offset":17,"length":1,"offsetbit":0,"scale":"1","mask":"0X000F"},{"type":"bool","name":"System Status","offset":18,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Do Not Disturb","offset":18,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"Mute","offset":18,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"AV Status","offset":18,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source","offset":18,"length":1,"offsetbit":0,"scale":"1","mask":"0X0007"},{"type":"bool","name":"WHM Status","offset":19,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Page Trigger","offset":19,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"DRC Status","offset":19,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"Loudness","offset":19,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source +7","offset":19,"length":1,"offsetbit":4,"scale":"1","mask":"0X0007"},{"type":"int8","name":"Volume","offset":20,"length":1,"offsetbit":4,"scale":"1","mask":"0X003F"},{"type":"int8","name":"Treble","offset":21,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"},{"type":"int8","name":"Bass","offset":22,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":140,"y":420,"wires":[["efa5c61d.1671f8"]]},{"id":"4375b9ec.e4f29","type":"buffer-parser","z":"256968c0.0d1b98","name":"Zone 3 Status","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"Zone","offset":23,"length":1,"offsetbit":0,"scale":"1","mask":"0X000F"},{"type":"bool","name":"System Status","offset":24,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Do Not Disturb","offset":24,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"Mute","offset":24,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"AV Status","offset":24,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source","offset":24,"length":1,"offsetbit":0,"scale":"1","mask":"0X0007"},{"type":"bool","name":"WHM Status","offset":25,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Page Trigger","offset":25,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"DRC Status","offset":25,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"Loudness","offset":25,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source +7","offset":25,"length":1,"offsetbit":4,"scale":"1","mask":"0X0007"},{"type":"int8","name":"Volume","offset":26,"length":1,"offsetbit":4,"scale":"1","mask":"0X003F"},{"type":"int8","name":"Treble","offset":27,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"},{"type":"int8","name":"Bass","offset":28,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":140,"y":720,"wires":[["70a971ea.d62918"]]},{"id":"d7c7554a.0a4ff","type":"buffer-parser","z":"256968c0.0d1b98","name":"Zone 4 Status","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"Zone","offset":29,"length":1,"offsetbit":0,"scale":"1","mask":"0X000F"},{"type":"bool","name":"System Status","offset":30,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Do Not Disturb","offset":30,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"Mute","offset":30,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"AV Status","offset":30,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source","offset":30,"length":1,"offsetbit":0,"scale":"1","mask":"0X0007"},{"type":"bool","name":"WHM Status","offset":31,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Page Trigger","offset":31,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"DRC Status","offset":31,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"Loudness","offset":31,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source +7","offset":31,"length":1,"offsetbit":4,"scale":"1","mask":"0X0007"},{"type":"int8","name":"Volume","offset":32,"length":1,"offsetbit":4,"scale":"1","mask":"0X003F"},{"type":"int8","name":"Treble","offset":33,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"},{"type":"int8","name":"Bass","offset":34,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":140,"y":1020,"wires":[["16a32dc5.fdd4a2"]]},{"id":"8ae2e0d7.1f0c2","type":"buffer-parser","z":"256968c0.0d1b98","name":"Zone 5 Status","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"Zone","offset":35,"length":1,"offsetbit":0,"scale":"1","mask":"0X000F"},{"type":"bool","name":"System Status","offset":36,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Do Not Disturb","offset":36,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"Mute","offset":36,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"AV Status","offset":36,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source","offset":36,"length":1,"offsetbit":0,"scale":"1","mask":"0X0007"},{"type":"bool","name":"WHM Status","offset":37,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Page Trigger","offset":37,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"DRC Status","offset":37,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"Loudness","offset":37,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source +7","offset":37,"length":1,"offsetbit":4,"scale":"1","mask":"0X0007"},{"type":"int8","name":"Volume","offset":38,"length":1,"offsetbit":4,"scale":"1","mask":"0X003F"},{"type":"int8","name":"Treble","offset":39,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"},{"type":"int8","name":"Bass","offset":40,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":140,"y":1320,"wires":[["1894b8c3.031c67"]]},{"id":"3a767c8d.a76394","type":"buffer-parser","z":"256968c0.0d1b98","name":"Zone 6 Status","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"Zone","offset":41,"length":1,"offsetbit":0,"scale":"1","mask":"0X000F"},{"type":"bool","name":"System Status","offset":42,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Do Not Disturb","offset":42,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"Mute","offset":42,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"AV Status","offset":42,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source","offset":42,"length":1,"offsetbit":0,"scale":"1","mask":"0X0007"},{"type":"bool","name":"WHM Status","offset":43,"length":1,"offsetbit":6,"scale":">>6","mask":"0X0040"},{"type":"bool","name":"Page Trigger","offset":43,"length":1,"offsetbit":5,"scale":">>5","mask":"0X0020"},{"type":"bool","name":"DRC Status","offset":43,"length":1,"offsetbit":4,"scale":">>4","mask":"0X0010"},{"type":"bool","name":"Loudness","offset":43,"length":1,"offsetbit":3,"scale":">>3","mask":"0X0008"},{"type":"int8","name":"Source +7","offset":43,"length":1,"offsetbit":4,"scale":"1","mask":"0X0007"},{"type":"int8","name":"Volume","offset":44,"length":1,"offsetbit":4,"scale":"1","mask":"0X003F"},{"type":"int8","name":"Treble","offset":45,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"},{"type":"int8","name":"Bass","offset":6,"length":1,"offsetbit":4,"scale":"1","mask":"0X001F"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":140,"y":1620,"wires":[["fb8ac281.668b68"]]},{"id":"b79bdb80.b01088","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Volume","tooltip":"","group":"2e2d63d0.910174","order":2,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":"1","x":760,"y":80,"wires":[["75292b3.93631d4"]]},{"id":"3a3cf662.7806e2","type":"debug","z":"256968c0.0d1b98","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1710,"y":180,"wires":[]},{"id":"fed83a11.85364","type":"serial request","z":"256968c0.0d1b98","name":"","serial":"4a242dbe.325f34","x":1450,"y":180,"wires":[["3a3cf662.7806e2"]]},{"id":"7419f7a4.f8a888","type":"switch","z":"256968c0.0d1b98","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Volume","vt":"str"},{"t":"eq","v":"Treble","vt":"str"},{"t":"eq","v":"Bass","vt":"str"},{"t":"eq","v":"Mute","vt":"str"},{"t":"eq","v":"Loudness","vt":"str"},{"t":"eq","v":"Source","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":450,"y":120,"wires":[["3c570e13.b72f82"],["ce70cfef.99b44"],["39ea1b8d.67a404"],["106bcf8d.d1931"],["89194e6e.4ffd8"],["384d03d6.4186ec"]]},{"id":"3c570e13.b72f82","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"48","minout":"100","maxout":"0","action":"scale","round":true,"property":"payload","name":"","x":620,"y":80,"wires":[["b79bdb80.b01088"]]},{"id":"75292b3.93631d4","type":"template","z":"256968c0.0d1b98","name":"&S86,VOL,01,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,VOL,01,{{payload}}","output":"str","x":1140,"y":80,"wires":[["fed83a11.85364"]]},{"id":"ce70cfef.99b44","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":120,"wires":[["7fe9fd72.573d04"]]},{"id":"7fe9fd72.573d04","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Treble","tooltip":"","group":"2e2d63d0.910174","order":3,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":120,"wires":[["9ed02c69.9a35"]]},{"id":"39ea1b8d.67a404","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":160,"wires":[["12160981.cd42de"]]},{"id":"12160981.cd42de","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Bass","tooltip":"","group":"2e2d63d0.910174","order":4,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":160,"wires":[["fca37d4c.3ced48"]]},{"id":"89194e6e.4ffd8","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Loudness","tooltip":"","group":"2e2d63d0.910174","order":6,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":760,"y":240,"wires":[["6be82fae.c6b25"]]},{"id":"384d03d6.4186ec","type":"ui_dropdown","z":"256968c0.0d1b98","name":"","label":"Source","tooltip":"","place":"Select option","group":"2e2d63d0.910174","order":1,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"Off","value":"0","type":"str"},{"label":"1","value":1,"type":"num"},{"label":"2","value":2,"type":"num"},{"label":"3","value":3,"type":"num"},{"label":"Volumio","value":4,"type":"num"},{"label":"Air Play","value":5,"type":"num"},{"label":"6","value":6,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","x":760,"y":280,"wires":[["16f97d06.44f16b"]]},{"id":"16f97d06.44f16b","type":"template","z":"256968c0.0d1b98","name":"&S86,AUD,01,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,AUD,01,{{payload}}","output":"str","x":1140,"y":280,"wires":[["fed83a11.85364"]]},{"id":"a9575fa4.080248","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":200,"wires":[["a513efce.041b38"]]},{"id":"a513efce.041b38","type":"template","z":"256968c0.0d1b98","name":"&S86,MUT,01,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,MUT,01,{{payload}}","output":"str","x":1140,"y":200,"wires":[["fed83a11.85364"]]},{"id":"6be82fae.c6b25","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":240,"wires":[["f8b7e5ac.b7a08"]]},{"id":"f8b7e5ac.b7a08","type":"template","z":"256968c0.0d1b98","name":"&S86,LUD,01,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,LUD,01,{{payload}}","output":"str","x":1140,"y":240,"wires":[["fed83a11.85364"]]},{"id":"9ed02c69.9a35","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":120,"wires":[["620ba69c.0bcad"]]},{"id":"b42ac999.e308","type":"template","z":"256968c0.0d1b98","name":"&S86,TRE,01,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,TRE,01,{{payload}}","output":"str","x":1140,"y":120,"wires":[["fed83a11.85364"]]},{"id":"620ba69c.0bcad","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":120,"wires":[["b42ac999.e308"]]},{"id":"fca37d4c.3ced48","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":160,"wires":[["ed44a2aa.014ca"]]},{"id":"912f13c8.2275e8","type":"template","z":"256968c0.0d1b98","name":"&S86,BAS,01,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,BAS,01,{{payload}}","output":"str","x":1140,"y":160,"wires":[["fed83a11.85364"]]},{"id":"ed44a2aa.014ca","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":160,"wires":[["912f13c8.2275e8"]]},{"id":"106bcf8d.d1931","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Mute","tooltip":"","group":"2e2d63d0.910174","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":750,"y":200,"wires":[["a9575fa4.080248"]]},{"id":"fcfb680f.59ffa","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Volume","tooltip":"","group":"3ad89b7f.21fe84","order":2,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":"1","x":760,"y":380,"wires":[["23d4b788.54c2f8"]]},{"id":"bce70938.1b486","type":"debug","z":"256968c0.0d1b98","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1710,"y":480,"wires":[]},{"id":"c8caa647.71e32","type":"serial request","z":"256968c0.0d1b98","name":"","serial":"4a242dbe.325f34","x":1450,"y":480,"wires":[["bce70938.1b486"]]},{"id":"efa5c61d.1671f8","type":"switch","z":"256968c0.0d1b98","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Volume","vt":"str"},{"t":"eq","v":"Treble","vt":"str"},{"t":"eq","v":"Bass","vt":"str"},{"t":"eq","v":"Mute","vt":"str"},{"t":"eq","v":"Loudness","vt":"str"},{"t":"eq","v":"Source","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":450,"y":420,"wires":[["21f99020.f3ed58"],["efd58a16.ba60e"],["2cbc7d2f.ccfe82"],["534370b9.c2c9"],["10b234c7.ddc74b"],["f231ff8f.e19e"]]},{"id":"21f99020.f3ed58","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"48","minout":"100","maxout":"0","action":"scale","round":true,"property":"payload","name":"","x":620,"y":380,"wires":[["fcfb680f.59ffa"]]},{"id":"23d4b788.54c2f8","type":"template","z":"256968c0.0d1b98","name":"&S86,VOL,02,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,VOL,02,{{payload}}","output":"str","x":1140,"y":380,"wires":[["c8caa647.71e32"]]},{"id":"efd58a16.ba60e","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":420,"wires":[["272e3360.8abc84"]]},{"id":"272e3360.8abc84","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Treble","tooltip":"","group":"3ad89b7f.21fe84","order":3,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":420,"wires":[["e17cbefd.35c23"]]},{"id":"2cbc7d2f.ccfe82","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":460,"wires":[["958352d4.417348"]]},{"id":"958352d4.417348","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Bass","tooltip":"","group":"3ad89b7f.21fe84","order":4,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":460,"wires":[["ede3ca13.f4068"]]},{"id":"10b234c7.ddc74b","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Loudness","tooltip":"","group":"3ad89b7f.21fe84","order":6,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":760,"y":540,"wires":[["8e39b243.742e88"]]},{"id":"f231ff8f.e19e","type":"ui_dropdown","z":"256968c0.0d1b98","name":"","label":"Source","tooltip":"","place":"Select option","group":"3ad89b7f.21fe84","order":1,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"Off","value":"0","type":"str"},{"label":"1","value":1,"type":"num"},{"label":"2","value":2,"type":"num"},{"label":"3","value":3,"type":"num"},{"label":"Volumio","value":4,"type":"num"},{"label":"Air Play","value":5,"type":"num"},{"label":"6","value":6,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","x":760,"y":580,"wires":[["7d4f8253.19c12c"]]},{"id":"7d4f8253.19c12c","type":"template","z":"256968c0.0d1b98","name":"&S86,AUD,02,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,AUD,02,{{payload}}","output":"str","x":1140,"y":580,"wires":[["c8caa647.71e32"]]},{"id":"d33d1e76.0fd898","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":500,"wires":[["b4e6c0e7.a212f"]]},{"id":"b4e6c0e7.a212f","type":"template","z":"256968c0.0d1b98","name":"&S86,MUT,02,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,MUT,02,{{payload}}","output":"str","x":1140,"y":500,"wires":[["c8caa647.71e32"]]},{"id":"8e39b243.742e88","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":540,"wires":[["8b3cb18b.904fe8"]]},{"id":"8b3cb18b.904fe8","type":"template","z":"256968c0.0d1b98","name":"&S86,LUD,02,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,LUD,02,{{payload}}","output":"str","x":1140,"y":540,"wires":[["c8caa647.71e32"]]},{"id":"e17cbefd.35c23","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":420,"wires":[["aebd4574.8e3468"]]},{"id":"10de901e.18729","type":"template","z":"256968c0.0d1b98","name":"&S86,TRE,02,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,TRE,02,{{payload}}","output":"str","x":1140,"y":420,"wires":[["c8caa647.71e32"]]},{"id":"aebd4574.8e3468","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":420,"wires":[["10de901e.18729"]]},{"id":"ede3ca13.f4068","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":460,"wires":[["7ebaa511.d0667c"]]},{"id":"7e26fb60.f2af04","type":"template","z":"256968c0.0d1b98","name":"&S86,BAS,02,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,BAS,02,{{payload}}","output":"str","x":1140,"y":460,"wires":[["c8caa647.71e32"]]},{"id":"7ebaa511.d0667c","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":460,"wires":[["7e26fb60.f2af04"]]},{"id":"534370b9.c2c9","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Mute","tooltip":"","group":"3ad89b7f.21fe84","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":750,"y":500,"wires":[["d33d1e76.0fd898"]]},{"id":"16f46158.ba4c77","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Volume","tooltip":"","group":"b88fe54d.e1b1f","order":2,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":"1","x":760,"y":680,"wires":[["d1121cb7.37c1b"]]},{"id":"b110ba87.477aa","type":"debug","z":"256968c0.0d1b98","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1710,"y":780,"wires":[]},{"id":"67ce9a39.abc13c","type":"serial request","z":"256968c0.0d1b98","name":"","serial":"4a242dbe.325f34","x":1450,"y":780,"wires":[["b110ba87.477aa"]]},{"id":"70a971ea.d62918","type":"switch","z":"256968c0.0d1b98","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Volume","vt":"str"},{"t":"eq","v":"Treble","vt":"str"},{"t":"eq","v":"Bass","vt":"str"},{"t":"eq","v":"Mute","vt":"str"},{"t":"eq","v":"Loudness","vt":"str"},{"t":"eq","v":"Source","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":450,"y":720,"wires":[["ce7512d.63e31f"],["4d551576.c13d3c"],["ef9e1788.78fef"],["21972e1a.629b3a"],["bb3b6d.9e3dc49"],["d2cc10bb.36519"]]},{"id":"ce7512d.63e31f","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"48","minout":"100","maxout":"0","action":"scale","round":true,"property":"payload","name":"","x":620,"y":680,"wires":[["16f46158.ba4c77"]]},{"id":"d1121cb7.37c1b","type":"template","z":"256968c0.0d1b98","name":"&S86,VOL,03,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,VOL,03,{{payload}}","output":"str","x":1140,"y":680,"wires":[["67ce9a39.abc13c"]]},{"id":"4d551576.c13d3c","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":720,"wires":[["c340383f.74da58"]]},{"id":"c340383f.74da58","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Treble","tooltip":"","group":"b88fe54d.e1b1f","order":3,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":720,"wires":[["38a9ae94.6a608a"]]},{"id":"ef9e1788.78fef","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":760,"wires":[["4ac333bf.ff7024"]]},{"id":"4ac333bf.ff7024","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Bass","tooltip":"","group":"b88fe54d.e1b1f","order":4,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":760,"wires":[["14ded0f.487af2f"]]},{"id":"bb3b6d.9e3dc49","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Loudness","tooltip":"","group":"b88fe54d.e1b1f","order":6,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":760,"y":840,"wires":[["4ef99ea7.57aa28"]]},{"id":"d2cc10bb.36519","type":"ui_dropdown","z":"256968c0.0d1b98","name":"","label":"Source","tooltip":"","place":"Select option","group":"b88fe54d.e1b1f","order":1,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"Off","value":"0","type":"str"},{"label":"1","value":1,"type":"num"},{"label":"2","value":2,"type":"num"},{"label":"3","value":3,"type":"num"},{"label":"Volumio","value":4,"type":"num"},{"label":"Air Play","value":5,"type":"num"},{"label":"6","value":6,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","x":760,"y":880,"wires":[["69a73449.6f92bc"]]},{"id":"69a73449.6f92bc","type":"template","z":"256968c0.0d1b98","name":"&S86,AUD,03,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,AUD,03,{{payload}}","output":"str","x":1140,"y":880,"wires":[["67ce9a39.abc13c"]]},{"id":"33e8008f.8143c","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":800,"wires":[["eabd2407.15011"]]},{"id":"eabd2407.15011","type":"template","z":"256968c0.0d1b98","name":"&S86,MUT,03,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,MUT,03,{{payload}}","output":"str","x":1140,"y":800,"wires":[["67ce9a39.abc13c"]]},{"id":"4ef99ea7.57aa28","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":840,"wires":[["5f4e2de1.668bcc"]]},{"id":"5f4e2de1.668bcc","type":"template","z":"256968c0.0d1b98","name":"&S86,LUD,03,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,LUD,03,{{payload}}","output":"str","x":1140,"y":840,"wires":[["67ce9a39.abc13c"]]},{"id":"38a9ae94.6a608a","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":720,"wires":[["6568830d.5a6044"]]},{"id":"e8c30914.de5268","type":"template","z":"256968c0.0d1b98","name":"&S86,TRE,03,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,TRE,03,{{payload}}","output":"str","x":1140,"y":720,"wires":[["67ce9a39.abc13c"]]},{"id":"6568830d.5a6044","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":720,"wires":[["e8c30914.de5268"]]},{"id":"14ded0f.487af2f","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":760,"wires":[["8a3070f4.f09208"]]},{"id":"ffd30d2.5a22f7","type":"template","z":"256968c0.0d1b98","name":"&S86,BAS,03,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,BAS,03,{{payload}}","output":"str","x":1140,"y":760,"wires":[["67ce9a39.abc13c"]]},{"id":"8a3070f4.f09208","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":760,"wires":[["ffd30d2.5a22f7"]]},{"id":"21972e1a.629b3a","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Mute","tooltip":"","group":"b88fe54d.e1b1f","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":750,"y":800,"wires":[["33e8008f.8143c"]]},{"id":"1ecd0730.181bd1","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Volume","tooltip":"","group":"faba34c5.2b4718","order":2,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":"1","x":760,"y":980,"wires":[["cc6f1f61.809de"]]},{"id":"fa351c9b.d5ea18","type":"debug","z":"256968c0.0d1b98","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1710,"y":1080,"wires":[]},{"id":"491962f6.bbb75c","type":"serial request","z":"256968c0.0d1b98","name":"","serial":"4a242dbe.325f34","x":1450,"y":1080,"wires":[["fa351c9b.d5ea18"]]},{"id":"16a32dc5.fdd4a2","type":"switch","z":"256968c0.0d1b98","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Volume","vt":"str"},{"t":"eq","v":"Treble","vt":"str"},{"t":"eq","v":"Bass","vt":"str"},{"t":"eq","v":"Mute","vt":"str"},{"t":"eq","v":"Loudness","vt":"str"},{"t":"eq","v":"Source","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":450,"y":1020,"wires":[["48441b64.5368ec"],["f15548f8.d2e638"],["18781137.26aa27"],["dbfa9e31.c3223"],["543ee1e0.603078"],["f020fbe.5bb9c88"]]},{"id":"48441b64.5368ec","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"48","minout":"100","maxout":"0","action":"scale","round":true,"property":"payload","name":"","x":620,"y":980,"wires":[["1ecd0730.181bd1"]]},{"id":"cc6f1f61.809de","type":"template","z":"256968c0.0d1b98","name":"&S86,VOL,04,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,VOL,04,{{payload}}","output":"str","x":1140,"y":980,"wires":[["491962f6.bbb75c"]]},{"id":"f15548f8.d2e638","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":1020,"wires":[["d7094c94.588e8"]]},{"id":"d7094c94.588e8","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Treble","tooltip":"","group":"faba34c5.2b4718","order":3,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":1020,"wires":[["fd1551b2.d60e8"]]},{"id":"18781137.26aa27","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":1060,"wires":[["7cac781.2205c88"]]},{"id":"7cac781.2205c88","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Bass","tooltip":"","group":"faba34c5.2b4718","order":4,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":1060,"wires":[["a87bba6d.34f73"]]},{"id":"543ee1e0.603078","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Loudness","tooltip":"","group":"faba34c5.2b4718","order":6,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":760,"y":1140,"wires":[["5816b54b.9995cc"]]},{"id":"f020fbe.5bb9c88","type":"ui_dropdown","z":"256968c0.0d1b98","name":"","label":"Source","tooltip":"","place":"Select option","group":"faba34c5.2b4718","order":1,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"Off","value":"0","type":"str"},{"label":"1","value":1,"type":"num"},{"label":"2","value":2,"type":"num"},{"label":"3","value":3,"type":"num"},{"label":"Volumio","value":4,"type":"num"},{"label":"Air Play","value":5,"type":"num"},{"label":"6","value":6,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","x":760,"y":1180,"wires":[["a90f3ff1.d1d7f8"]]},{"id":"a90f3ff1.d1d7f8","type":"template","z":"256968c0.0d1b98","name":"&S86,AUD,04,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,AUD,04,{{payload}}","output":"str","x":1140,"y":1180,"wires":[["491962f6.bbb75c"]]},{"id":"b9b23414.85609","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1100,"wires":[["18baf38a.fdf814"]]},{"id":"18baf38a.fdf814","type":"template","z":"256968c0.0d1b98","name":"&S86,MUT,04,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,MUT,04,{{payload}}","output":"str","x":1140,"y":1100,"wires":[["491962f6.bbb75c"]]},{"id":"5816b54b.9995cc","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1140,"wires":[["f8f11ecb.bdd128"]]},{"id":"f8f11ecb.bdd128","type":"template","z":"256968c0.0d1b98","name":"&S86,LUD,04,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,LUD,04,{{payload}}","output":"str","x":1140,"y":1140,"wires":[["491962f6.bbb75c"]]},{"id":"fd1551b2.d60e8","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":1020,"wires":[["84b843a4.1e43f"]]},{"id":"a98ef258.fe58","type":"template","z":"256968c0.0d1b98","name":"&S86,TRE,04,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,TRE,04,{{payload}}","output":"str","x":1140,"y":1020,"wires":[["491962f6.bbb75c"]]},{"id":"84b843a4.1e43f","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":1020,"wires":[["a98ef258.fe58"]]},{"id":"a87bba6d.34f73","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":1060,"wires":[["1fdfd855.a46b9"]]},{"id":"ffcc3287.fb01","type":"template","z":"256968c0.0d1b98","name":"&S86,BAS,04,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,BAS,04,{{payload}}","output":"str","x":1140,"y":1060,"wires":[["491962f6.bbb75c"]]},{"id":"1fdfd855.a46b9","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":1060,"wires":[["ffcc3287.fb01"]]},{"id":"dbfa9e31.c3223","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Mute","tooltip":"","group":"faba34c5.2b4718","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":750,"y":1100,"wires":[["b9b23414.85609"]]},{"id":"c3d5cea.363923","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Volume","tooltip":"","group":"65fa626a.295a6c","order":2,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":"1","x":760,"y":1280,"wires":[["4101144.b06c56c"]]},{"id":"5f74b6d2.e642b","type":"debug","z":"256968c0.0d1b98","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1710,"y":1380,"wires":[]},{"id":"9f350dff.8a6ff","type":"serial request","z":"256968c0.0d1b98","name":"","serial":"4a242dbe.325f34","x":1450,"y":1380,"wires":[["5f74b6d2.e642b"]]},{"id":"1894b8c3.031c67","type":"switch","z":"256968c0.0d1b98","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Volume","vt":"str"},{"t":"eq","v":"Treble","vt":"str"},{"t":"eq","v":"Bass","vt":"str"},{"t":"eq","v":"Mute","vt":"str"},{"t":"eq","v":"Loudness","vt":"str"},{"t":"eq","v":"Source","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":450,"y":1320,"wires":[["795b9b53.63e12c"],["e2f0cd84.057f7"],["db430556.92c41"],["b1cee0e3.bbb7a"],["fb761709.d3869"],["f6f27095.fdb82"]]},{"id":"795b9b53.63e12c","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"48","minout":"100","maxout":"0","action":"scale","round":true,"property":"payload","name":"","x":620,"y":1280,"wires":[["c3d5cea.363923"]]},{"id":"4101144.b06c56c","type":"template","z":"256968c0.0d1b98","name":"&S86,VOL,05,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,VOL,05,{{payload}}","output":"str","x":1140,"y":1280,"wires":[["9f350dff.8a6ff"]]},{"id":"e2f0cd84.057f7","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":1320,"wires":[["7e7b6859.dff7e8"]]},{"id":"7e7b6859.dff7e8","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Treble","tooltip":"","group":"65fa626a.295a6c","order":3,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":1320,"wires":[["9dedb9c2.fa5668"]]},{"id":"db430556.92c41","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":1360,"wires":[["6ad2df35.84ac7"]]},{"id":"6ad2df35.84ac7","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Bass","tooltip":"","group":"65fa626a.295a6c","order":4,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":1360,"wires":[["31439100.c2f978"]]},{"id":"fb761709.d3869","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Loudness","tooltip":"","group":"65fa626a.295a6c","order":6,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":760,"y":1440,"wires":[["853bc7ee.b80bc8"]]},{"id":"f6f27095.fdb82","type":"ui_dropdown","z":"256968c0.0d1b98","name":"","label":"Source","tooltip":"","place":"Select option","group":"65fa626a.295a6c","order":1,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"Off","value":"0","type":"str"},{"label":"1","value":1,"type":"num"},{"label":"2","value":2,"type":"num"},{"label":"3","value":3,"type":"num"},{"label":"Volumio","value":4,"type":"num"},{"label":"Air Play","value":5,"type":"num"},{"label":"6","value":6,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","x":760,"y":1480,"wires":[["7a08ebd6.525b5c"]]},{"id":"7a08ebd6.525b5c","type":"template","z":"256968c0.0d1b98","name":"&S86,AUD,05,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,AUD,05,{{payload}}","output":"str","x":1140,"y":1480,"wires":[["9f350dff.8a6ff"]]},{"id":"26709a34.a844ee","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1400,"wires":[["9723c4e4.1c2b5"]]},{"id":"9723c4e4.1c2b5","type":"template","z":"256968c0.0d1b98","name":"&S86,MUT,05,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,MUT,05,{{payload}}","output":"str","x":1140,"y":1400,"wires":[["9f350dff.8a6ff"]]},{"id":"853bc7ee.b80bc8","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1440,"wires":[["5b7a9069.597f88"]]},{"id":"5b7a9069.597f88","type":"template","z":"256968c0.0d1b98","name":"&S86,LUD,05,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,LUD,05,{{payload}}","output":"str","x":1140,"y":1440,"wires":[["9f350dff.8a6ff"]]},{"id":"9dedb9c2.fa5668","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":1320,"wires":[["889ec494.59e708"]]},{"id":"46c06be6.083954","type":"template","z":"256968c0.0d1b98","name":"&S86,TRE,05,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,TRE,05,{{payload}}","output":"str","x":1140,"y":1320,"wires":[["9f350dff.8a6ff"]]},{"id":"889ec494.59e708","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":1320,"wires":[["46c06be6.083954"]]},{"id":"31439100.c2f978","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":1360,"wires":[["307b684f.3309a"]]},{"id":"e321e9b0.65d9e","type":"template","z":"256968c0.0d1b98","name":"&S86,BAS,05,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,BAS,05,{{payload}}","output":"str","x":1140,"y":1360,"wires":[["9f350dff.8a6ff"]]},{"id":"307b684f.3309a","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":1360,"wires":[["e321e9b0.65d9e"]]},{"id":"b1cee0e3.bbb7a","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Mute","tooltip":"","group":"65fa626a.295a6c","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":750,"y":1400,"wires":[["26709a34.a844ee"]]},{"id":"a8e69c57.a0365","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Volume","tooltip":"","group":"cd5b9d62.4ec54","order":2,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":"1","x":760,"y":1580,"wires":[["10e68006.5a884"]]},{"id":"7b5473d4.237fdc","type":"debug","z":"256968c0.0d1b98","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1710,"y":1680,"wires":[]},{"id":"9e5ae729.a7ca58","type":"serial request","z":"256968c0.0d1b98","name":"","serial":"4a242dbe.325f34","x":1450,"y":1680,"wires":[["7b5473d4.237fdc"]]},{"id":"fb8ac281.668b68","type":"switch","z":"256968c0.0d1b98","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Volume","vt":"str"},{"t":"eq","v":"Treble","vt":"str"},{"t":"eq","v":"Bass","vt":"str"},{"t":"eq","v":"Mute","vt":"str"},{"t":"eq","v":"Loudness","vt":"str"},{"t":"eq","v":"Source","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":450,"y":1620,"wires":[["cb437ce9.f41a7"],["b1d11d3f.e0b5b"],["86850d19.840b78"],["f30fa252.e4a4b8"],["fc15ece8.d6a57"],["13dec453.e03f54"]]},{"id":"cb437ce9.f41a7","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"48","minout":"100","maxout":"0","action":"scale","round":true,"property":"payload","name":"","x":620,"y":1580,"wires":[["a8e69c57.a0365"]]},{"id":"10e68006.5a884","type":"template","z":"256968c0.0d1b98","name":"&S86,VOL,06,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,VOL,06,{{payload}}","output":"str","x":1140,"y":1580,"wires":[["9e5ae729.a7ca58"]]},{"id":"b1d11d3f.e0b5b","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":1620,"wires":[["985a91d4.1db588"]]},{"id":"985a91d4.1db588","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Treble","tooltip":"","group":"cd5b9d62.4ec54","order":3,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":1620,"wires":[["1ba81ad5.164f4d"]]},{"id":"86850d19.840b78","type":"range","z":"256968c0.0d1b98","minin":"4","maxin":"28","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"","x":620,"y":1660,"wires":[["d2e0b01a.60ff8"]]},{"id":"d2e0b01a.60ff8","type":"ui_slider","z":"256968c0.0d1b98","name":"","label":"Bass","tooltip":"","group":"cd5b9d62.4ec54","order":4,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"100","step":1,"x":750,"y":1660,"wires":[["5e75fa4.57da384"]]},{"id":"fc15ece8.d6a57","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Loudness","tooltip":"","group":"cd5b9d62.4ec54","order":6,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":760,"y":1740,"wires":[["a5210c3a.0b67c"]]},{"id":"13dec453.e03f54","type":"ui_dropdown","z":"256968c0.0d1b98","name":"","label":"Source","tooltip":"","place":"Select option","group":"cd5b9d62.4ec54","order":1,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"Off","value":"0","type":"str"},{"label":"1","value":1,"type":"num"},{"label":"2","value":2,"type":"num"},{"label":"3","value":3,"type":"num"},{"label":"Volumio","value":4,"type":"num"},{"label":"Air Play","value":5,"type":"num"},{"label":"6","value":6,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","x":760,"y":1780,"wires":[["8aa444a9.26fef"]]},{"id":"8aa444a9.26fef","type":"template","z":"256968c0.0d1b98","name":"&S86,AUD,06,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,AUD,06,{{payload}}","output":"str","x":1140,"y":1780,"wires":[["9e5ae729.a7ca58"]]},{"id":"641d72b7.66036c","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1700,"wires":[["ab14275b.ba8478"]]},{"id":"ab14275b.ba8478","type":"template","z":"256968c0.0d1b98","name":"&S86,MUT,06,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,MUT,06,{{payload}}","output":"str","x":1140,"y":1700,"wires":[["9e5ae729.a7ca58"]]},{"id":"a5210c3a.0b67c","type":"change","z":"256968c0.0d1b98","name":"True = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1740,"wires":[["cb8c6156.d99d2"]]},{"id":"cb8c6156.d99d2","type":"template","z":"256968c0.0d1b98","name":"&S86,LUD,06,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,LUD,06,{{payload}}","output":"str","x":1140,"y":1740,"wires":[["9e5ae729.a7ca58"]]},{"id":"1ba81ad5.164f4d","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":1620,"wires":[["93a43e0.6d883c"]]},{"id":"b5c98ca3.f90c78","type":"template","z":"256968c0.0d1b98","name":"&S86,TRE,06,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,TRE,06,{{payload}}","output":"str","x":1140,"y":1620,"wires":[["9e5ae729.a7ca58"]]},{"id":"93a43e0.6d883c","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":1620,"wires":[["b5c98ca3.f90c78"]]},{"id":"5e75fa4.57da384","type":"range","z":"256968c0.0d1b98","minin":"0","maxin":"100","minout":"-6","maxout":"+6","action":"clamp","round":true,"property":"payload","name":"","x":870,"y":1660,"wires":[["1109cc45.963bd4"]]},{"id":"6e0ff92.a7ae308","type":"template","z":"256968c0.0d1b98","name":"&S86,BAS,06,","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"&S86,BAS,06,{{payload}}","output":"str","x":1140,"y":1660,"wires":[["9e5ae729.a7ca58"]]},{"id":"1109cc45.963bd4","type":"change","z":"256968c0.0d1b98","name":"add +","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"+1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"+2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"+3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"+4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"+5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"+6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":1660,"wires":[["6e0ff92.a7ae308"]]},{"id":"f30fa252.e4a4b8","type":"ui_switch","z":"256968c0.0d1b98","name":"","label":"Mute","tooltip":"","group":"cd5b9d62.4ec54","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":750,"y":1700,"wires":[["641d72b7.66036c"]]},{"id":"4a242dbe.325f34","type":"serial-port","serialport":"/dev/ttyS0","serialbaud":"19200","databits":"8","parity":"none","stopbits":"1","waitfor":"&","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"200","bin":"bin","out":"interbyte","addchar":"\\r","responsetimeout":"2000"},{"id":"2e2d63d0.910174","type":"ui_group","name":"Living Room","tab":"ad6aa3e1.5258e8","order":1,"disp":true,"width":"6","collapse":false},{"id":"3ad89b7f.21fe84","type":"ui_group","name":"Kitchen","tab":"ad6aa3e1.5258e8","order":2,"disp":true,"width":"6","collapse":false},{"id":"b88fe54d.e1b1f","type":"ui_group","name":"Patio","tab":"ad6aa3e1.5258e8","order":3,"disp":true,"width":"6","collapse":false},{"id":"faba34c5.2b4718","type":"ui_group","name":"Zone 4","tab":"ad6aa3e1.5258e8","order":4,"disp":true,"width":"6","collapse":false},{"id":"65fa626a.295a6c","type":"ui_group","name":"Study","tab":"ad6aa3e1.5258e8","order":5,"disp":true,"width":"6","collapse":false},{"id":"cd5b9d62.4ec54","type":"ui_group","name":"Zone 6","tab":"ad6aa3e1.5258e8","order":6,"disp":true,"width":"6","collapse":false},{"id":"ad6aa3e1.5258e8","type":"ui_tab","name":"Elan Control","icon":"dashboard","disabled":false,"hidden":false}]
Collection Info
prev
Created 4 years, 5 months ago
  • change (x24)
  • debug (x6)
  • range (x30)
  • switch (x6)
  • template (x36)
  • Elan
  • s86
  • multizone
  • amplifier
